YB Crank and Cam sensor Pin out polarity
Good day Gentlemen;
Currently wiring a YB Cosworth to an aftermarket ECU.
I need to verify the polarity on the two pin connectors that plug into the VR sensors on both the crank and distributor......pin 1 pin 2
I take it both sensors are the same polarity?
Thanks for the assistance!
Re: YB Crank and Cam sensor Pin out polarity
Go on bigturbo.co.uk all the info there mate
The Following User Says Thank You to xpackboy For This Useful Post:
